Pro Lightning Powerhouse Problems
Old Nov 7, 2002 | 01:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Ok i just got my Pro Lightning 64cc chamber 200 cc runner heads and they have single springs. They also have a note that came in the box that says "not recommended from roller cams". The only reason i got these heads was that they came with dual springs, so i could run my XR274R-12 solid roller cam. What should i do? I am already gonna call and complain, but what else?
Old Nov 7, 2002 | 01:56 PM
ede's Avatar
ede
well if the phone call doesn't get you anywhere all that's left is to return them or machine the spring seats out for larger springs, if they aren't already and run the springs you want. do thay have screw in studs or pull out studs? you need screw in studs.
Old Nov 7, 2002 | 01:58 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
They come assembled with guide plates and screw-in studs. They have 1.550" springs.
Old Nov 7, 2002 | 04:13 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Well i just talked to the guy at Powerhouse, Rick. He said that if i'm under the max lift i should be fine. He also said that they went away from the dual springs and went with the single springs. They supposedly have a 130# seat pressure intalled at 1.880 with .100" longer valves. Do you guys think i will have any problems running them as they are, mainly valve float, and valves hitting pistons.
ME Leigh
Old Nov 7, 2002 | 04:16 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
well.. the XR series are really street solid rollers
they use similar springs to the hydraulic grinds. They really arn't designed for 6500+ rpm and for that reason, should be ok with the spring installed.
Old Nov 7, 2002 | 09:28 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Good thats what i wanted to here.
Old Nov 8, 2002 | 11:24 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
What does comp cams recomend for springs? Seat, open pressure, and rate. I'd use what comp cam recomends for springs.
Old Nov 9, 2002 | 02:38 AM
GilmourD's Avatar
Hey, how long did it take to receive the heads?
Old Nov 9, 2002 | 12:05 PM
Damon's Avatar
Wait a minute. I thought you could get an assembled version with big honkin dual springs for a roller cam.
To Quote Summit's catalog:
K3 kit: Designed for roller cams, this kit includes 1.540" dual springs with damper (190 lbs. seat pressure at 1.900"/450 lbs. open pressure at 1.300"), .660" max lift, chromemoly retainers, and 10* locks.
I DO notice however, that they just offer one generic roller cam version of the head, not the separate hydraulic roller and solid roller versions they used to. The above roller cam version looks very similar to the old solid roller version they used to list. And it's a very serious spring! You would destroy any hydraulic lifter with that much pressure- solid or flat tappet.
The milder K2 kit has 1.46" dual springs and only 135 lbs. seat pressure springs. They list it as being for solid flat tappet cams, but I suppose it would also work OK for a mild hydraulic roller as well.
Old Nov 9, 2002 | 01:30 PM
jimmy_mac's Avatar
It's been a while since I've looked but those dual springs from comp cams for that cam are only like 80 bucks and I believe they are 1.55 od also. Worth checking out and while the heads are off may be worth the peice of mind to get them.
Magman
Sep 12, 2015 10:43 PM
Americanmouse
Sep 7, 2015 12:10 PM
Ducati900ss
Sep 2, 2015 09:05 AM
someone972
Aug 30, 2015 12:52 AM
LT1Formula
Aug 20, 2015 09:36 PM
