Hot Cam dowel question: Not a how-to question either...
Old Nov 7, 2002 | 08:07 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
This question is about the length of the dowel. From the factory, the dowel extends .620 out of the cam for use with ?vented? optispark ignitions correct? They tell you to put it to .30 for other uses, I would imagine non-vented opti. Here is my question, for our genI SBC, it doesn't matter how long it is as long as it fits the sprocket and doesn't interfier with anything else right? It is currently about .45 but extends no further than the cam bolts, so will I be cool? That dowel is really soft steel and I don't want to beat on it again if I don't have to. Thanks
Old Nov 7, 2002 | 08:58 PM
rezinn's Avatar
It's fine as long as it doesn't hit the timing cover.
Old Nov 7, 2002 | 10:40 PM
Vader's Avatar
Rezinn is all over it. As long as it clears, you're o.K.
Those '93 and early '94 OptiSparks were a real F'ed up mess. No vacuum forced vent, but a drain so that road moisture could get in (¿What the hell was that about?)
You could remove and cut the dowel if you were so inclined, or grind it down as long as it's not in the engine, but if it clears the cover, forget about it.
Old Nov 7, 2002 | 11:44 PM
It's all good. Thanks for the insurance guys.
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
