lights dim with brakes
Old Nov 8, 2002 | 12:40 AM
FU-Q's Avatar
my lights (headlights, dash, dome, ect.) dim everytime i press my brake, even in park. also i sometimes hear a "crack" or "pop" when i press it, but the brakes work fine, when i first got my car i had to replace this little plastic push button piece that operates the brakelights, could this be going out again and some how draining or leaking the power?
Old Nov 8, 2002 | 12:48 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the brake lights do draw some power form the system and if your alt is weak youll notice a drop in power. The cracking and poping sounds like you may have a short.
Old Nov 8, 2002 | 12:54 AM
FU-Q's Avatar
i know my alt is good
Old Nov 8, 2002 | 01:45 AM
89WS-6's Avatar
I have a problem similar to that. If the lights are off, and it is in park, then I touch my brakes, my whoile instrument panel lights up. Im thinking its a short (mine and yours) but I dont worry about it.
Old Nov 8, 2002 | 02:00 AM
FU-Q's Avatar
ya, it's not too bad. just kinda annoying.
Old Nov 8, 2002 | 10:38 AM
Vader's Avatar
If the alternator is good, start looking at the power connections. Battery, starter, fusible links, fuse panel bus bars, etc.
Old Nov 8, 2002 | 11:40 AM
Sciguyjim's Avatar
The popping sound could be from dirty/worn contacts in the brake light switch too. Replace it again.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
