305 to 350 Swapout
Old Nov 8, 2002 | 12:35 PM
kdgreen's Avatar
305 to 350 Swapout
I have a Iroc that I am going to put a new crate motor with standard carburetor in. My only question is when I take out the computer/ecm and smog crap will all my gauges be able to be hooked up to work? Any help greatly appreciated.
Old Nov 8, 2002 | 12:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
All gauges will work, but if you have an auto, you'll have to take care of the TC lockup somehow, not a major thing though.
what crate engine you lookin at gettin?
Old Nov 8, 2002 | 12:56 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
and you have to run your fuel pump off the computer and reduce the pressure, or disconnect it and put in a mechanical
Old Nov 8, 2002 | 12:57 PM
TBI305Camaro's Avatar
Ok the speedo should work since its cable driven in most 3rd gens i do believe. The oil pressure gauge is controlled by a sender...varies from year to year. My temp gauge is controlled by the sensor on the drivers side head.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
