Someone tell me the symptoms...
Old Nov 8, 2002 | 08:36 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
of a bad IAC sensor. Would it cause problems sometimes without throwing a code? My car has a hard time getting back to idle and sometimes won't even idle and just die. If I hold the gas to keep the car alive around the idle area it will run rough at first and eventually smooth out if sitting long enough with the gas being pressed. Won't run rough though once out of the 1000 RPM and below range. Would this be a bad IAC or MAF?
Old Nov 8, 2002 | 09:00 PM
z28_dave's Avatar
From: tokyo - where the girls are pretty and the cars are fast
a bad IAC can cause a high idle or no idle at all.
Old Nov 8, 2002 | 10:34 PM
Vader's Avatar
And an IAC motor is very easy to clean.
Old Nov 9, 2002 | 12:49 AM
trans87's Avatar
So does my problem sound like its stemming from the IAC?
jrmints1415
Feb 21, 2014 09:51 PM
TKR 88 GTA
Sep 7, 2012 12:18 PM
strokercutlass
Mar 14, 2012 08:45 PM
gerard
Mar 29, 2009 08:23 PM
jester_587
Oct 12, 2008 01:55 PM
