Help with heads,cam, and intake install..
Old Nov 10, 2002 | 12:36 AM
beamar's Avatar
91 Camaro RS 305 TBI
K, I have my heads all ready and started to yank off the old junk.
I have a set of headmen headers with Y-pipe I'm going to use for now. Since there is no AIR lines for them, So I do away with all my emissions junk under the hood? What do I do about the smog pump?
My new cam isn't a roller, Do I still need to use that valley piece that goes over all the lifters?
The heads I'm using are from a 96 350 with centerbolts. THey aren't LT1's, just standard centerbolts. I bought a set of 1.6 roller rockers from a friend. They are non-self aligning. He said they were the ones that NEED to be used with guide plates. Needless to say I don't have guide plates or intend to buy and install them, will they be fine?
How is my stock computer going to do for now will all the mods listed below? Will it run ok intil I get the stuff to make my own chips?
Centerbolt 350 heads - ported and polished. Milled for extra compression.
Performer Intake
Holley 670
Headman heads and Y pipe
Flowmaster 3" cat back
Crane Cams non-roller Hdy. 454/454 218/218
Summit 1.6 Roller rockers.
.530 lift dual springs
160 thermo
timimg @ 14°
thats about it....
info on the rockers:
Vendor: Summit Racing Equipment
Product Line: Summit Steel Roller Tip Rocker Arms
Material: Hardened Steel
Horsepower and durability
Small Chevy: 1955-87 262-400, 1.6 ratio, 3/8 in. stud rockers
Get the horsepower and durability you want at a price that suits you with this set of roller tip rocker arms from Summit Racing. Formed from heat-treated steel with a long slot design and precision ground rollers, these rockers will deliver the performance you're after--even in high lift applications. Each set includes rocker arms, grooved rocker *****, and nuts.
Sold in sets of 16.
Old Nov 10, 2002 | 05:39 AM
ede's Avatar
ede
you either remove the air pump and use a shorter belt or leave it. don't need the spider, how you going ot install guide plates? you need to pull the studs, machine the casting tap the holes then put in screw in studs, gets pretty expensive to make a set of heads work and to freshen them up compared to buying a new set. WAG from the springs you list you'll need to get the spring seats enlarged too. if you swap from a roller to flat cam you'll need longer push rods too.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Mickeyruder
Sep 2, 2015 02:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
