anyone using trick flow heads and hotcam help please!
Old Nov 11, 2002 | 12:29 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I'm looking for the correct lenth push rods to use on my engine. I've got a 90 model L98 and I'm going with tf 23* heads, lt4 hotcam and crane 1.5 roller rockers. I really need some help because I want to tear into the engine next week.
Old Nov 11, 2002 | 12:32 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i asked this same question when i put my trickflows on, and the answer i got was that it's impossible to predict what length your gonna need. You HAVE to measure with an adjustbale length pushrod. The heads come with a reference guide that says what length they *should* be, dependent on what rocker your using. It's your job to verify that...
hope this helps,
Eric
Old Nov 11, 2002 | 01:08 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Zupman has it. Measuring them is the way to go. But the TFS install guide has some common parts combos and what length they *should* need. As a reference, I am using 7.300" ones on mine with Comp Pro Mag 1.6:1 rockers.
Also, why are you even entertaining the idea of using the 1.5 rockers with those heads and the LT4 HC?
Old Nov 11, 2002 | 03:13 PM
Damon's Avatar
Having actually worked on a similar combo I can tell you DON'T go blindly by TF's specs on their web site. My ideal length pushrods (measured) turned out to be about .200" shorter than their recommended ones! Yikes!
Old Nov 11, 2002 | 05:12 PM
slayer2000's Avatar
Car: 1990 GTA
I'm using 1.5 rockers because my boss gave me a good set for free. Also the heads specs say that .520 is the max lift. I don't think .005 would hurt but I don't want to take the chance.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
