Oil pressure gauge freaking out
Old Nov 11, 2002 | 12:36 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I just drove my 91 Formula from my home near Dayton, OH to Indianapolis and back. I noticed on the way back that my oil pressure gauge was freaking out and jumping all over the place. It will sit at a certain pressure for a few seconds, then it will jump and max out to the right for a second, then it will go back down, then it will jump up a little, then back down... and it just goes all over the place. What the heck....?
Old Nov 11, 2002 | 01:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Max indication = max sender resistance, which also = disconnected wire.
Check the wire; if it's OK, you need a sending unit.
Old Nov 11, 2002 | 01:30 PM
gruveb's Avatar
Car: 1989 IROC-1
Another thing it could be is a lose connection. I know mine will go a little postal now and then and it is just because the connection is getting loose.
Old Nov 12, 2002 | 10:17 AM
FyreLance's Avatar
Thanks for the info...
where do I check? behind the gauge cluster?
Old Nov 12, 2002 | 10:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
At the sending unit. Behind the distributor.
Old Nov 12, 2002 | 11:09 AM
FyreLance's Avatar
Alright, thanks, I'll see if I can't find it
(I don't know exactly what I'm looking for, guess I'm 'bout to learn though )
Old Nov 12, 2002 | 11:53 AM
camaro_1983_383's Avatar
it may also be a loose wire behind the gauge.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
