LT4 Hot Cam RPM range?
Old Nov 12, 2002 | 06:19 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I was wondering what was GM calling the LT4 Hot Cam rpm range?
Brian
Old Nov 12, 2002 | 06:35 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Right off of my LT4 Hot Cam Spec sheet: ENG. RPM Range 1500-5500rpm There ya go. That is what they are calling for.
Old Nov 12, 2002 | 07:38 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
holy *****, you have a spec sheet? can you give me all the info on it? my cam didnt come with a card and i've never been able to find specs like ivo, evo, centerline, etc. thanks!:hail:
Old Nov 12, 2002 | 08:38 PM
Yes please send a copy of the spec sheet, mine didn't come with one either.
Brian
Old Nov 12, 2002 | 10:53 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Its HOLY HAIRY ***** to you Mr.! J/K I'll just post the cam spec card! I have no way of getting it up on the internet, sorry. Here ya go. Eng Type: SBC
Lifter Type: Hyd Roller
Eng RPM Range: 1500-5500 rpm
Engine Family: 1986 present Gen 1 and Gen 2 engines
Specifications: INTAKE EXHAUST
Lobe Lift: 0.328 .328"
Gross Valve Lift: .525" .525"Measured@valve w/1.6r
Lobe Centerline: 109degree 115degree
Duration@.006": 272 281 Duration measured@ cam lift
Duration@.050": 219 228 Duration measured@ cam lift
Rocker Arm Ratio: 1.6 1.6
Valve Adjustment: zero lash zero lash
Lobe Seperation: 112
Valve Lift with 1.5 rocker ratio is .492"
Spring Recommendation Part Number: 12551483
Outside Diameter: 1.337"
Installed Height: 1.780"
Seat Load: 101 lbs
Solid Height: 1.215"
Recommend using 10212809 spring seat and 10212808 retainer.
Well, that is all that is on there besides the cam kit's part#! Hope it helps-Bryan
Old Nov 12, 2002 | 11:03 PM
Car: '87 Camaro LT
Engine: 355 L98
thanks. have you ever seen the cam timing specs for this cam (evo, ivo, etc)? apparently gm is very secretive about it, they wouldn't give it to me.
Old Nov 13, 2002 | 12:13 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
nope! sorry
theshackle
Sep 17, 2020 08:26 AM
80s Poncho
Aug 19, 2015 06:45 PM
Jake_92RS
Aug 17, 2015 09:42 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
