Key stuck, cost to fix?
Old Nov 15, 2002 | 05:56 PM
Dave 89's Avatar
The car is a 1987 Camaro, w/ a 2.8l v6 automatic. The lock cylinder will not turn, the key does come out though. I have tried to turn the steering wheel and the key at the same time but no luck. I have also tried playing with the shifter, it moves in and out of park. What I want to know is what a dealer or shop will charge me to have this fixed. Thanks in advance
Old Nov 15, 2002 | 06:23 PM
ajm_shorty's Avatar
hey
That has happened to me before...what i did was i just kept working on it trying to turn the ignition and eventually it will pop out then go to a hardware store and spray some graphite spray into the lock...It wont happen again
Old Nov 15, 2002 | 11:52 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I replaced my gnition lock cylinder with a new one for $15 from Schucks. Mine was stuck on and wouldn't turn back i had to, turn the key to start and grind the starter to shut it off. All you need to do is pull the steering wheel off with a puller and remove the screw holding it in. Pull out the old one and put the new one in.
midge54
Dec 27, 2019 04:14 PM
Papaginos
Sep 27, 2015 03:29 PM
WIzmo
Aug 30, 2015 02:30 PM
JHX
Aug 29, 2015 02:30 PM
