Normal Idle?
Old Nov 15, 2002 | 08:30 PM
MrNova's Avatar
Normal Idle?
Hey, my car seems to be running pretty fine, but the Idle seems a bit low. When I start it, it fast idles to about 1k or so, then drops down to 700 in Park. When I switch to Neutral, Reverse, or Drive it sinks down to 500-550. It stays steady but all the same it seems rather low. This happens when I first turn the car on, and even after its been driving for some time and warmed up.
Old Nov 15, 2002 | 08:32 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
assuming the GTA is still TPI then I have no idea. When TBI does that all you can do is make sure you have fresh filters and good pressure. Check for codes, then check the TPI boards.
Old Nov 15, 2002 | 08:39 PM
lunas's Avatar
my 305 tpi idels like that
Old Nov 15, 2002 | 11:55 PM
MrNova's Avatar
Yeah its a TPI, and ive got no codes.
Old Nov 16, 2002 | 12:18 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
An idle of 500 rpm sounds about right. When you start the car it should idle higher until it warms up a little.
Bubbajones_ya
Jul 6, 2024 08:32 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
