Timing chain question
Old Nov 15, 2002 | 11:00 PM
radiateu2's Avatar
May sound like a dumb question but I am sure someone else is wondering about this too. How tight should a new timing chain be?
Old Nov 15, 2002 | 11:12 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Timing chain question
When its installed on the motor it should be quite tight.
You should only be able to deflect the chain say .5inch tops.
Old Nov 15, 2002 | 11:18 PM
radiateu2's Avatar
Thanks f-bird
Thats what I got did you read your mail?
Old Nov 16, 2002 | 05:41 AM
ede's Avatar
ede
new doesn't really matter unless the maker screwed up. there isn't an adjustment. to check for wear hold the chain sideways and it shouldn't sag more then the thickness of the chain, or about a 1/2". i never reuse a chain or gear set if i'm in to an engine were they're exposed.
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
redmaroz
Aug 16, 2015 11:40 PM
