Lower radiator hose question
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Just a quickie. My lower radator hose burst the other week so I took it off and inside it there was a coil (like a large spring) inside it. Went to put the new one on today and I cn't for the life of me find that coil that was in it. I've never seen a coil in a radiator hose before and was wondering if it came from the factory or if it was added by a previous owner to try and stop the hose collapsing??
Anyone have any insight?
Thanks for the time
Robert
Thanks for the time
Robert
Car: 87 IROC
Engine: modded LB9
ede,
Thanks for the quick reply.
I can't find the spring anywhere and as this is my UK car and I'm currently over there I'll fabricate one from an old metal coat hanger or something. Should do the job just fine. Of course you do realize that I will find it in about 2 days time.
Robert
Robert
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Mine didn't have the spring. My replacement didn't have one either. Personally I don't find the spring necessary. If the hose needs the spring to keep from collapsing then the hose is too soft/worn and needs to be replaced anyway.
I have yet to have any problems with my springless lower rad hose.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
