block numbers questions
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
trying to find out if an engine in a TA is a 305 or 350. The engine is tpi and supposedly converted from 305 to 350 but I can't tell just from looking. I was under the engine and on each side of the block there are the numbers 627. Does this mean anything? I thought the block number would be like 7 digits or something. Can anyone tell me exactly where to find the block number and how to tell if the engine is a 350 after I've found the number? Thanx.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
We need to know what the casting number is first.
There "might" be a number cast into the block saying 5.0L or 5.7L but not always. You can't make a 305 into a 350 so if it says 5.0L then it's a 305.
Car: 4
Engine: 6
Transmission: 5
Car: 98 Z28
Engine: 346 LS1
thanx for the help. I did look at the casting number. I can make out a "GM 5. L G" on the back of the block behind the driver's side head. I can't make out whether it says 5.7 or 5.0, looks like the second digit has been scratched with something. Maybe an attempt to scratch it off. Thanx again.
Car: 4
Engine: 6
Transmission: 5
You already posted the one number that tells all, which was the 627. That's the last 3 digits of the block casting number. It's all you need to know.
You have a 305. No further research is required.
