Can this be fixed by myself, or.......
Old Nov 17, 2002 | 11:33 PM
Thip22's Avatar
Hi, I just checked my camaro manually, and i got the codes 32 and 54. I was wondering if i could fix these problems myself, or should i take it in. Thanks.
Old Nov 18, 2002 | 02:32 AM
rezinn's Avatar
Code 32 is commonly set for a failing egr sensor, which isn't that difficult to replace. What kind of car is this? if TPI, there are some good pics of the valve here: https://www.thirdgen.org/techbb2/sho...hreadid=142466 Good info there anyway, thanks to Vader. As Vader also says in that thread, code 54 is shows low voltage to the fuel pump. Does the car run? If you poke around with a voltmeter or a test light between the fuel pump and the battery you should find something--maybe a failed relay, fuse, or wiring.
It's always good to include too much info when posting about a problem. Details about the car and how it's running/not running help. Good luck.
Old Nov 20, 2002 | 01:53 PM
Thip22's Avatar
Thanks for the good information. I should be trying to fix this project this weekened. Thanks.
Old Nov 20, 2002 | 03:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've had a code 32 for months now lol.
Too tight to spend the money for the EGR valve just yet - it's like $52 for an el cheapo at Advance Auto. I did replace my EGR solenoid in a failed attempt to solve the problem - that was only $17, but alas no luck (was worth a shot though). So I run with a SES half the time, but doesn't seem to affect drivability for me.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
