Problem with stealth ram fuel rails.....
Old Nov 18, 2002 | 06:40 AM
Cam28_boy's Avatar
I'm having trouble with fuel getting threw the holley adjustable fuel regulator. I switched back to the non-adjustable regulator and the same thing was happening. The fuel pumps from the fuel pump right up to the regulator and doesn't go through out the entire fuel rail. Would like to hear from anybody with a holley stealth ram that may have had a similar problems.
Old Nov 18, 2002 | 06:49 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Re: Problem with stealth ram fuel rails.....
Someone correct me if i'm wrong, but shouldn't the fuel go through the rails FIRST, then to the regulator, where it bleeds off excess pressure to the return line?
Old Nov 18, 2002 | 07:15 AM
Cam28_boy's Avatar
so the high pressure line goes to which part of the fuel rail?
Old Nov 18, 2002 | 07:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The high pressure line goes to one end of a fuel rail; the other end of that one goes to the end of the other rail; then the regulator goes at the end of the second rail, with the return line hooked to it.
The regulator sort of "bleeds off" fuel to lower the pressure. It doesn't go in-line like the ones we're used to for carbs do.
Old Nov 18, 2002 | 08:09 AM
Cam28_boy's Avatar
bless both of your hearts...I feel so stupid...thank *** for this site :hail:
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
92camaroJoe
Aug 13, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
