Vortec Head Question
Old Nov 18, 2002 | 03:02 PM
92WhiteRS's Avatar
Me and one of my friends are building up an engine that will be used in his 87 2.8 firebird. We're looking for 400hp on a budget, and was wondering if Vortec heads on a 350 could achieve this? And if so, what else would be needed to match the heads. Also, we are thinking about strocking the engine to a 383, but would Vortecs still flow enough for this size motor. He doesn't want to go and spend 1k+ on Brodix or Dart heads, if we could use Vortecs. Alright, any advice would be appreciated.
Matt
Old Nov 18, 2002 | 03:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You're going to need a higher lift cam than the springs can handle I would think, so some work would need to be done there.
oh, i know where he can get some awesome heads in aluminum for $870 shipped, just need 2 more buyers.... I just ordered a set myself.
Old Nov 18, 2002 | 03:40 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
yeah, i have a set of vortecs myself. theyd work for 383 or 350. mark is right about the valve springs. depends on how much of a budget you are on....but the cast iron is MUCH cheaper which is what i got
Old Nov 18, 2002 | 03:44 PM
92WhiteRS's Avatar
Thanks for the reply Mark. Do you think that the machined heads from Scoggin Dickey will be good enough? They accept .550 inches of lift, and that would be near the limit of what my friend wants to run, because he wants it to be streetable. Also, what kind of heads are those aluminum ones you were talking about. I want to go with AFR's but if something comes up that seems like a better deal...I'll go for it.
Matt
Old Nov 18, 2002 | 03:58 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
.550 lift isnt exactly streetable if you ask me. your power brakes are long gone
Old Nov 18, 2002 | 04:22 PM
87GTA Runner's Avatar
Car: 87 GTA
Hey, Mark A Shields. Where are you getting those aluminum heads from? I'm looking right now for heads for my 87 5.7L. I am very interested in hearing about these and If they would work for me
Old Nov 18, 2002 | 04:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Vortec Head Question
Matt
Go to http://www.chevyhiperformance.com/
Click on Search and type in "Vortec". There is aton of info on
different vortec headed buildups from past issues.
All the answers and more are there.
Old Nov 18, 2002 | 05:15 PM
Car: 99 Formula
Axle/Gears: 342
If you use roller, it helps streetablility a lot.
Old Nov 18, 2002 | 05:16 PM
Car: 99 Formula
Axle/Gears: 342
check your PM's
Old Nov 18, 2002 | 05:31 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I am using these heads with .510/.520 lift with a roller. Brakes are good, and steetability is real good. Idles rough, but constant so I agree with Mark. The Vortecs from Scoggin-Dickey would work just fine if they are in your budget.
Old Nov 19, 2002 | 02:02 AM
titeride85's Avatar
400 hp on a budget...definately vortecs. Either S-D or Wheeler motorsports. Both allow for .550 lift but I am not sure if S-D machines in the 1.6 exhaust valve. I know Wheeler does.
As far as what to go with it, Comp cams XE-268, Edelbrock performer RPM intake (vortec style of course), Speed demon 750 carb, 1.6 rockers (Crane has nice stamped steel rockers cheap), Hedman 1-5/8 headers, MSD or Flamethrower ignition, Blue Max wires, Bosch platinum or NGK plugs, and a good exhaust system.
Also try to calculate for .040" quench. So if you are decking the block or just buying head gaskets, keep it in mind.
Old Nov 19, 2002 | 10:57 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Do you need to drill and tap the vortec heads to bolt on the accessory brackets or do the holes line up?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
