355 w/ 56cc Vortec heads... Which Pistons??
Old Nov 20, 2002 | 04:11 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Gonna build a 355 block for my car this x-mas. I have Vortec heads that are shaved to a hair over 56cc.
Which pitons should I get that will yield 10-1 compression?
Most of the time they give the desired compression when used with 64cc heads. Is there some kind of easy equation to figure out how much compression rises per cc milled on the 350 block???
Since I milled 8 cc's off, doesn't that raise the compression about a point or a little more???
Old Nov 20, 2002 | 04:28 PM
Polecat's Avatar
Here's ya a hole lot to choose from...these are TRW forged, so if you want a diffeent brand, go back to main page and look at other brands...good luck!
350 pistons
Old Nov 20, 2002 | 04:41 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
thanks..
Looks like if I get a full .030 kit I'll need pistons that yield about 9.3-9.4 compression when used with 64cc heads.
Old Nov 20, 2002 | 04:43 PM
Polecat's Avatar
Yep, and if you've had the heads shaved to 56cc, that puts you right there where you wanna be...good luck!
84z96L31vortec
Aug 20, 2017 12:16 AM
BLK87Z
Sep 18, 2015 11:29 PM
JHX
Aug 29, 2015 02:30 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
