Code diagnosis and the Fan/shift light comes on, Is this normal???
Old Nov 22, 2002 | 06:41 AM
88irock's Avatar
Hey all, when I put a paperclip across pins A and B of the diagnostic port under the dash, to check for trouble codes, the cooling fan under the hood comes on and the ^UPSHIFT light comes on. This is with the key on, but the car isn't running. The decoding portion works fine, or at least it seems to, 1_2___1_2___1_2, then the codes set, etc.The fan and light stay on until the decoding is done, I turn the key off and remove the paperclip. Afterward, with the key on, all is normal, and when the car is running, all is OK there too.
Is this normal, or do I have a problem??
Old Nov 22, 2002 | 07:54 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I know that in my car, my fan turns on when checking codes. No upshift light but I'm an auto.
Old Nov 22, 2002 | 10:30 AM
88irock's Avatar
Anyone else with a stick shift car?
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Omega
Aug 10, 2015 12:46 PM
