Cam button?
Old Nov 23, 2002 | 10:57 AM
GTA600's Avatar
Cam button?
We have a roller cam engine and are replacing the cam, do we need a thrust plate or cam button?
Old Nov 23, 2002 | 11:40 AM
Vader's Avatar
Button? I prefer zippers....
Actually, once you remove the timing sprocket from the cam, you should see a thrust plate already bolted to the front of the case. The factory put that there just for your use in case you ever wanted to change the cam.
(Not trying to be sarcastic - just keeping it light.)
Unless the thrust plate is heavily worn, you should be able to reuse it succesfully. If it doesn't have one for some reason, you really need to get one.
One thing you might want to consider replacing is the distributor drive gear, however. These do tend to wear and may not be in as good a condition as they appear. The cost of a replacement is cheap insurance.
Jorlain
Oct 8, 2015 01:57 AM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
Strick1
Sep 4, 2015 07:11 AM
luvofjah
Sep 3, 2015 07:08 PM
masonta
Sep 1, 2015 06:40 PM
