Post UR ENGINE!! VROOOOM
Old Nov 24, 2002 | 09:48 PM
  #51
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
kaz i have the same plug wires as you. im trying to find blue ones though.
Old Nov 24, 2002 | 09:55 PM
  #52
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Kaz: That isn't your IAT duct taped into you intake duct is it?
Nope it is the MAF, just temperary till i get my Induction system fabbed up.
I beleive MSD makes blue ones.
Old Nov 24, 2002 | 10:10 PM
  #53
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
1992 305 TBI LO3 15.4 @ 90mph. 159,000 miles. Getting an LT1 cam next month.
  #54
screw it, it's too big. There's a pic on my homepage though.
Old Nov 24, 2002 | 11:27 PM
  #55
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
How'd I get what on my air cleaner??
Old Nov 25, 2002 | 12:09 AM
  #56
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
Originally posted by brodyscamaro
dude, that looks like a desktop dyno 2000 screen. for one many have found that to be inaccurate. it told me a 305 with a zz4 cam and vortec heads would make 380 HP. i am guessing that isnt going to happen. for two, DD2000 is NOT a chassis dyno, it estimates crank HP without any accesories. with stock exhaust manifolds im sure your not over 300 RWHP, do you still have the stock catalytic converter on it too? put the thing on a dyno as it is right now. something that will spit out a sheet for you. with those manifolds, i am gonna go out on a limb and say you dont have over 300 RWHP. let us know. i got no pics of my engine bay. there are a lot of the wires there that are not necessary and the damn AC is still in there i need to clean it up. then engine itself is painted gloss black. the front accessory brackets were bead blasted so they are clean and the intake was just bead blasted so its clean also
well i know, i think that that run was with my new exhaust on, hooker shorties and a borla race muffler, i entered those but i havent put them on yet, i just wanted to see, and this is at the crank, not wheel, i with it had this at the wheel though, but i have a built tranny (700R4), but again i am sorry if i come across as an idoet but i will post my dyno sheets, new ones, in january when my car club goes and gets dynoed.
Old Nov 25, 2002 | 05:06 AM
  #57
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
92RS fivepoint slow I love the Rebel Flag where did you get that? That is awesome!
Old Nov 25, 2002 | 06:51 AM
  #58
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
heres mine right after the new intake and carb...
  #59
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
one more
Old Nov 25, 2002 | 03:07 PM
  #60
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
$$$ of chrome plating?
what does it cost to get a pair of valve covers chrome plated/finished? id post a pic, but my engine isn't much to look at. '72 short block without any paint is all i have assembled so far
Old Nov 25, 2002 | 04:05 PM
  #61
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's mine. Since the pic I've added new plug wires and a different set of wire looms that keep them a lot neater. I'm hoping to get some ceramic headers next summer.
Old Nov 25, 2002 | 04:08 PM
  #62
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Jim, I see a red IROC in the sig, yet the pics you posted lookk orange
Old Nov 25, 2002 | 04:14 PM
  #63
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Heres mine
Old Nov 25, 2002 | 04:21 PM
  #64
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Here's mine...
Old Nov 25, 2002 | 04:37 PM
  #65
Squeeks83's Avatar
geeseus christ johnsjj2,
that is one beatiful engine bay, what all did you take out of there and how hard was it, i want to do that to my camaro. that again looke SWEET!! nice and clean like i like them.
Shean
Old Nov 25, 2002 | 06:12 PM
  #66
johnsjj2's Avatar
Car: 1991 Z-28
I'm glad you like it. I wanted to keep things simple. A/C, and heat, I could live without. I don't drive the car when its cold, and if its hot enough to require A/C, then I will stay at home! I cut all the wires, vacuum tubes going to the heater plenum, just past the firewall, in the engine bay. I then took all of the plenum out, made plates to cover the holes, and presto, all done. I want to get the drivers side better also. It still looks to cluttered. It was pretty easy, but if you ever plan on using your defrost, heat, or any air movement at all, don't take it out.
Old Nov 25, 2002 | 06:41 PM
  #67
85_ZED28's Avatar
Car: '85 Z28
stock LG4
400 posts cooool
Old Nov 25, 2002 | 11:24 PM
  #68
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
i still need to do some wire routing and looming but you get the point
Old Nov 25, 2002 | 11:31 PM
  #69
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I dunno if I count, but here's one for grins.
To the very left of this crappy picture you can see my gas pedal!
...no the plug wires aren't like that anymore...
Old Nov 25, 2002 | 11:36 PM
  #70
Car: 1984 Z28
whats with those air filter things on the valve covers?! What do they do? and why do you have 2 of them.
Old Nov 26, 2002 | 12:04 AM
  #71
Car: 1989 camaro RS
Engine: RAMJET 350
82z28 if you are refering to my engine. those are breathers, i have 2 because my pcv valve it right in my intake manifold. usually on tpi cars and what not u have a pcv valve on one valve cover and an air tube goin to the airbox allowing air to follow in the valve cover. thats the best i can explain that
Old Nov 26, 2002 | 07:55 AM
  #72
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
<b> with stock exhaust manifolds im sure your not over 300 RWHP</b>
You can make over 400 N/A horsepower with the stock manifolds on a small block 355.
Old Nov 26, 2002 | 09:44 AM
  #73
Car: 99 Formula
Axle/Gears: 342
I guess so, but look at his mods, there's not way he's at 300 hp with his setup.
Old Nov 26, 2002 | 10:02 PM
  #74
Car: 1984 Z28
about the breathers,
i have a pcv valve (a little hose going into the valve cover?) on the one valve cover and the oil cap on the other.. did u just replace those with breathers? how does this help the engine?
Old Nov 26, 2002 | 10:47 PM
  #75
Car: 1989 camaro RS
Engine: RAMJET 350
i didnt replace them my pcv valve is in my manifold. i have the ramjet 350 so i didnt need to put a pcv in the valve cover because it came with one. and i still have an oil cap. i just needed to put somethin in the holes that were there. so i put breathers. and it does what it says it lets the motor breath. i didnt notice any performance because i went from a v6 to a crate motor
Old Nov 27, 2002 | 09:03 AM
  #76
Jim85IROC's Avatar
My camera seems to hate florescent lights. It makes my car look orange. It makes my friend's hugger orange SS look pink.
Old Nov 27, 2002 | 09:04 AM
  #77
Jim85IROC's Avatar
And I'll bet the exact same combo could make well over 450hp with headers. Nobody spends the kind of money necessary to get 400hp and chokes the **** out of their motor with stock manifolds.
Old Nov 27, 2002 | 09:58 AM
  #78
some AIM buddy icon website I found a long time ago. Tried to look for it, but I couldn't find it again.
Old Nov 27, 2002 | 03:55 PM
  #79
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
well that is cool, especially coming from a guy from NJ. Just pulling your leg.
Old Nov 27, 2002 | 06:59 PM
  #80
Car: 1984 Z28
i cant get my *** damn HEADLIGHT BLACKOUTS TO FRIGGIN FIT!!!!!!!!!!!!!!!!!!!!!! the velcro in them is like the size of a ****ing penny. JESUS. and the *** damn tailight blackouts are ****ing BROKEN AND NOW I GOTTA WAIT 4 DAYS TO ORDER NEW ONES WHEN BEFORE IT TOOK 1 DAY TO GET HERE!! JESUS ****NIG CHRIST!! WHATS GOING TO HAPPEN NEXT!!!!!
i had to get that out.
Old Nov 27, 2002 | 07:08 PM
  #81
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Focus...Focus. Anger will only brake more things. Focus!!!!
Old Nov 27, 2002 | 07:09 PM
  #82
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>And I'll bet the exact same combo could make well over 450hp with headers.</b>
of course it would. I never said Stock manifolds should be used, Ever, in any application, even stock. heh.
I just mentioned its possible for somone to make over 400 horsepower with the stock manifolds.
Old Nov 28, 2002 | 01:40 AM
  #83
BlueByU's Avatar
Car: 1991 Z28
Jim85Iroc or Superman
Where did you get those valve covers? I've been looking for them.
Old Nov 28, 2002 | 12:41 PM
  #84
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Before:
After:
hehe
Daz
Old Nov 28, 2002 | 01:30 PM
  #85
DABE's Avatar
damn.....
heres mine...
WHO STOLE MY ENGINE!!!!!!
AHHHH THERES THE 400+hp N/A BEAST!!!
worldsportsman II heads...1.65roller rockers on the intake and 1.5s on the exhaust....
shes an all roller motor...
She will be rocking and rolling by sunday
Let me know if u guys want to know what she has on the inside...
Old Nov 28, 2002 | 01:32 PM
  #86
DABE's Avatar
why wont it show the other 2 pics????...WTF...
Old Nov 28, 2002 | 04:59 PM
  #87
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Daz, what happened to cause that mess? That looks bad.
Old Nov 28, 2002 | 06:00 PM
  #88
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
BlueByU
I got my valve covers from http://www.sdpc2000.com/
Old Nov 28, 2002 | 06:22 PM
  #89
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
heres mine
Old Nov 28, 2002 | 06:24 PM
  #90
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
Old Nov 28, 2002 | 06:35 PM
  #91
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
sorry about the triple post. i was having some problems when i first made the posts. i just edited everything to be correct now.
Old Nov 28, 2002 | 06:58 PM
  #92
Car: 1984 Z28
man i love my camaro.
Old Nov 28, 2002 | 07:25 PM
  #93
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
This is the motor thats going into my '85.
377 (new block w/383 crank)
10.6:1 compression
AFR 195 heads
LPE 219 cam (originally bought an LT4 hot cam but decided against it)
LT4 roller rockers
Eagle rods and crank
Superram (just the plenum and runners...have quite a bit of porting to do on the base)
No way thing will breath through the stock exhaust so i still need a good set of headers and a cat back.
Right now this 5000 dollar piece of metal is still sitting on a stand, taking up space in my garage as i haven't had time to drop it in, not to mention i have a few other odds and ends that i need to take care of (new fuel pump, ecm, etc etc)
Old Nov 28, 2002 | 07:27 PM
  #94
DABE's Avatar
AFatHippo: thats an interesting belt setup you have there...have any info on it...looks like u moved everything around...
DABE
Old Nov 28, 2002 | 07:37 PM
  #95
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Since that pic, I switched over to a dual fan setup so all those little stickers are gone.
Old Nov 28, 2002 | 07:38 PM
  #96
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is my first setup,
My second Setup
and part of my new setup,
This is going ontop of that LT1 block,
Old Nov 28, 2002 | 09:40 PM
  #97
Car: 1984 Z28
is that all the same car?
Old Nov 28, 2002 | 10:28 PM
  #98
DABE's Avatar
Zepher....is that teflon tape or paste on the nitrous lines??....i dont want to be a dick...but...if its tape u want it to be paste...the tape will descinagrate (spell?)..then clog your soleniods...
DABE
Old Nov 29, 2002 | 01:29 AM
  #99
Zepher's Avatar
Yes, that is the same car. Been through a lot of changes these past 3 years that I've owned it.
And yes, that is teflon tape, which I didn't put on.
My friend was putting part of this setup on his Honda before I got it and he was using tape. I'll be using paste.
Here are a couple of vids of my car,
This one is with the carb on it,
15.04 1/4 mile run
Video with the new TPI setup
Old Nov 29, 2002 | 04:02 PM
  #100
Desert86Roc's Avatar
