Do you really need EGR on a TBI car?
Old Nov 24, 2002 | 06:38 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
I've got a performer intake without an EGR provision that I would like to use. Is there any way I could use it? I will be doing a head and cam swap (416 heads and hopefully an LT1 cam) on my LO3 real soon and I already had this intake in my part stockpile. I know there will be a SES code issue but will it hurt performance, engine life, reliability, and gas mileage? Thank you for any info.
P.S. I know that the LT1 cam has a ground in EGR.
Old Nov 24, 2002 | 06:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Is TBI really necessary on a car with EGR?
Aside from the codes, it should work.. you may have trouble with spark knock sometimes though.
Old Nov 25, 2002 | 10:03 AM
Vader's Avatar
Since you may want to burn a custom PROM for your car after the cam swap, you could remove the EGR error codes.
Old Nov 25, 2002 | 10:39 AM
TBI305Camaro's Avatar
I know where you can get a lt1 cam for cheap. Check my sig.
Im pretty sure the lt1 cam has a self EGR provision or something. You sure the performer is for your year heads? 87 and up?
Old Nov 25, 2002 | 12:33 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
So far, my experience is the TBI heads cause knock at WOT before the lack of EGR can cause ping at part throttle.
Old Nov 25, 2002 | 08:08 PM
Car: '84 Z28
I am also swapping heads to the 416's. I don't want to mess with the swirl port heads. The 416's that I got have the old intake bolt pattern.
MustangBeater20
Oct 29, 2022 09:20 PM
camaroken83
Aug 10, 2015 11:35 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
