AFR or fastburn heads
Old Nov 24, 2002 | 08:27 PM
worldofool's Avatar
I was planning to use a miniram or lt1 on a 383. Which heads would flow better or make more power, I would be running at high rpms like 6500.
Old Nov 24, 2002 | 08:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The AFR are far superior and i thin are about the same price. The fastburns are pretty much just aluminum vortecs. They are good but not that good.
Old Nov 24, 2002 | 09:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Why not Pro Lightnings?
Old Nov 26, 2002 | 03:49 PM
chacane67's Avatar
Between the two heads questioned, the AFR's.
Mark has raised an excellent question though......
Old Nov 26, 2002 | 04:02 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
From what i understand the AFRs, but i will be using the fastburns b/c thats what came with the motor! I am also using the miniram. They are basically aluminum vortecs but from what i have heard they have great potential when worked. I did not have any work done to them. They are on the crate motor. Out of the box the AFRs from what people say! good luck
Old Nov 26, 2002 | 05:15 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I think saying the Fastburns and the Vortecs are pretty much the same is like saying a Cavalier is pretty much a Camaro.
Old Nov 26, 2002 | 05:27 PM
Blackroc86's Avatar
Car: 1986 Iroc
Here is the flow ratings of the two heads from purplesagetradingpost.com/sumner/techinfo/heads1.html
lift GM Fastburns GM Vortec
.100 62/55 70/49
.200 136/104 139/105
.300 187/133 190/137
.400 232/158 227/151
.500 266/180 239/160
.600 275/193 229/162
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
