All of a sudden --NO HEAT?
Old Nov 26, 2002 | 04:21 PM
SoSoFresh_SS's Avatar
Car: 1984 Firebird
Engine: 2.8L V6
Hey guys this is non-3rd gen!
I have a 84' Caprice Coupe and my heat was working perfectly until today. Now nothing but cold air is coming out of my vents. The only mods I have is a new carb, alternator, and battery.DOES ANYONE OUT THERE HAVE A DIAGNOSIS FOR THIS PROBLEM?
Old Nov 26, 2002 | 04:27 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if your blower motors still working its probably a blockage in the cooling system, most likely buildup in the heater core.. other possiblities would be a low coolant level, but you'd probably notice a leak or something if this just came on.. i'd say blockage in the heater core.. try flushing the cooling system
Old Nov 26, 2002 | 04:28 PM
CamaroDriver's Avatar
Possibly a heater control valve.
Somewhere in between the radiator and the heater core (firewall) there may be a black valve in the heater hose. If there is, then more than likely that's the culprit.
If there isn't one there, check the level of your antifreeze. If it's low, there isn't enough in there to heat up anything, including the engine.
Old Nov 26, 2002 | 04:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, check the vacuum connection to the heater control valve. Right next to the carb.
Old Nov 26, 2002 | 09:20 PM
Damon's Avatar
Also, it could be a bad flapper door/related control hardware that splits the air intake between cold outside air and air that gets drawn through the heater core. On the Caprice I think it' just a cable that's hooked up between the hot/cold control lever and the lever that works the flapper under the dash. I've seen the arm on the flapper door itself also break.
Um....... ya know, if you have a coolant leak and drain most of the coolant out of the system you can also end up with a no-heat situation shortly before you overheat the motor, too. Just thought I'd throw in the super-obvious.
Old Nov 26, 2002 | 09:54 PM
SomeDodgeGuy's Avatar
Or maybe its as simple as a thermostat.
Old Nov 27, 2002 | 10:05 AM
Vader's Avatar
Got coolant?
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
