Comp Cams 08-412-8 + S/R Torquer Heads?
Old Nov 29, 2002 | 01:15 AM
Acidtalons's Avatar
I am currently rebuilding a '87 305 and planning (hoping) to run a Comp Cams Extreme Energy Hydraulic Roller Cam 08-412-8, it has .495 intake lift and .502 exhaust lift. Using a 1.5 rocker arm ratio its valve lift would be .742 intake and .753 exhaust. World Castings S/R Torquer heads are listed at max lift of .56. Is it possible to get the two to work together? If not can anyone recommend an alternative head?
Old Nov 29, 2002 | 01:22 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You got it confused. The lift spec listed is the lift at the valve
with a 1.5 rr. .495/.502" is the valve lift. Th cam lobe lift is.330"/.3346"
Old Nov 29, 2002 | 01:27 AM
Acidtalons's Avatar
I suspected as much but I wasn't sure, thanks for straightening me out.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
