thick intake gaskets to help alignment?
Old Nov 30, 2002 | 03:25 PM
blown 83's Avatar
Car: camaro
Engine: 8-71 blown 355
Transmission: TH400
Axle/Gears: 9inch 4.30:1
just a quick question for ya,
is it a common practice to use thicker intake gaskets to help align intake ports on the inatake to the heads if the intake ports on the intake seem too low by about a 1/16th or a hair more lower than the head ports.
or would this raise the distrubuter too high and throw off the distributer gear to cam gear mesh and screw with timing or cause distributer gear wear or oil pump shaft enguagement problems.
1992 Trans Am
May 10, 2023 07:19 PM
92projectcamaro
Jan 18, 2016 08:00 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
NinjaNife
Aug 23, 2015 11:49 AM
