can a bad o2 sensor cause backfire?
Old Nov 30, 2002 | 05:47 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
My car has been backfiring lately when I let off the gas. Today I replaced the plugs, distributor cap, rotor, ignition module and fuel filter. I regained most of my power but the car still backfires after high rpms when I let off teh gas. It seems to be running lean when I step on the gas and get rich when I let off. Could the o2 sensor be bad?
Old Nov 30, 2002 | 11:17 PM
anyone?
Old Dec 1, 2002 | 06:10 AM
Andy Bush's Avatar
Are you getting an engine fault light?
It sounds more like the distributer is wearing out. Get a timing light and check if the timing is wandering around instead of staying constant in the same place when the engine is at a steady rpm.
Old Dec 1, 2002 | 08:50 AM
there is no check engine light. everything seems fine. i will check the timing i guess and see whats goin on.
db057
Jan 10, 2020 08:55 PM
tyeo098
Nov 30, 2015 06:27 PM
L98GTA87
Oct 19, 2015 10:43 PM
racereese
Oct 3, 2015 03:46 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
