i need help....engine wont start
Old Dec 1, 2002 | 12:11 PM
maddmonkees90rs's Avatar
well ive posted this one the tbi board but i dont think theyll be able to help to much. infact i should have posted here first. basically the car wont start. it cranks but no fuel. i tried the pump directly to the battery and it worked, i tried it while cranking but no fuel came out of the injectors. so basically im not gettin fuel from the pump or the injectors, i also think im not gettin spark. when i turn the key the security light comes on for two seconds and then turns off. so i doubt its the vats. i checked the fuse next to the battery under that hood and it looks good but its not gettin a current. all the fuses look good too. this all happend after a engine change because my first one went out. what could cause this problem? please help. thanks in advanced. also is the break light supposed to turn on while cranking the engine?
Old Dec 1, 2002 | 02:35 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I believe all the warning lights should come on when the key is in the 'start' position as a 'lights test' feature.
Old Dec 1, 2002 | 04:48 PM
but why wont it start?
Old Dec 2, 2002 | 12:29 AM
guess no one knows......
Old Dec 2, 2002 | 12:33 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You could at least state what motor you have...,,,
EDIT: oh it's tbi. ok, Try disconnecting the 4 wire connector at the ignition module and see if it starts. You probably have a bad ignition module or pick-up coil. This will cause the injector to not fire.
EDIT #2: OK, you just put the motor in and it's hasn't run at all?
Did you forget to hook anything up?? Look over the whole primary ignition system for any broken/disconnected wires.....
Old Dec 2, 2002 | 01:26 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
You just put the motor in? Check your grounds, especially the one on the back of the cylinder head, passenger side, I believe. That one is easy to miss.
Verify that. It makes a big difference as to what the cause is.
Old Dec 2, 2002 | 10:30 AM
well there are no missing wires or broken connections for the ignition. and i belive ive grounded everything... im sure i got both grounds that are behind the heads. and ill try disconnecting the plug but what exactly am i supposed to look for? ill also verify weather im gettin spark or not. thanks guys. i really need the car so any help is greatly apreiciated.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
