Pics of my aluminum Pro Lightnings (not modem friendly)
Old Dec 2, 2002 | 10:18 PM
  #51
Momar's Avatar
Originally posted by ME Leigh
I'm gonna stroke mine too. Hopefully the bore isn't warn, so i get sloppy pison slap.
When the bore gets worn too much you should get rid of the block and get a nice fresh one that way you dont have to worry about blow by on your power stroke. Oh, and mark, you are a moderator now you shouldnt laugh at this kind of stuff. j/k
Ben
Old Dec 3, 2002 | 01:37 AM
  #52
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
You should go out to a dyno and get a pull with your old heads, then do the head install. Then go back and get another pull with the new heads. I would also get em' flow tested, I'd like to see some numbers, see if they actually stack up to what they print.
JM2C
Old Dec 3, 2002 | 05:36 AM
  #53
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
You mean I have to use a header gasket on these heads.
The gasket is up to you Mark. Did I mention gaskets????
I have found with large D shaped exhaust port the only headers that will cover the ports and seal are 1 3/4 primaries.
Old Dec 3, 2002 | 09:42 AM
  #54
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
JM2C
can't already sold the old heads.
Old Dec 3, 2002 | 11:25 AM
  #55
poorboy8's Avatar
Car: 79 Camaro RS
Transmission: TH350
So does this mean the new ones are on?
Got any numbers, did you get them flow tested, are you gonna dyno it, what about SOTP??? Some feeback would be great!
Old Dec 3, 2002 | 01:19 PM
  #56
Momar's Avatar
I sure as hell hope he gets some sotp feedback along with better track times because compared to what he should have been doing he was doing horible.
Ben
Old Dec 3, 2002 | 02:08 PM
  #57
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
$675 Heads
Originally posted by AJ_92RS
Are these the same heads for $675? They look to be.
http://www.enginekits.com/heads/heads1.html
AJ
If you download the company's catalog, it say's they're Cast Iron Heads......
Old Dec 3, 2002 | 02:55 PM
  #58
Car: 99 Formula
Axle/Gears: 342
no, they're not on, it was too cold this past weekend whne I was at home. Hopefully this coming weekend though.
I think I found the culprit to my sucky track times, we put my old carb on my bros 305 truck and it ran like crap, put a 750 Holley on it and ran great.
Old Dec 3, 2002 | 04:23 PM
  #59
Momar's Avatar
I kind of figured it was the carb. You may have been able to pick up 1-2 secs with just a carb. Imagine that.
Ben
Old Dec 3, 2002 | 04:32 PM
  #60
Car: 99 Formula
Axle/Gears: 342
Ben
lol, yeah no chit, now $1k later. Oh well, least I'll be running faster.
Old Dec 3, 2002 | 08:42 PM
  #61
Guest
Guest
Posts: n/a
Is it just me, or do those intake port floors look to be ramped up pretty high?
Old Dec 4, 2002 | 05:40 AM
  #62
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Nope your not seeing things at all.
This is one of the differences between an aftermarket head and a stock head.
The port spreads apart as it approaches the bowl. It needs to maintain the same approximate cross sectional area. So the floor raises up to maintain this cross sectional area. It just so happens that this ramp helps the flow get ready to turn the corner into the bowl. This ramp and floor short side radius
causes the floor flow to follow is contour and into the cylinder.
Other wise it (airflow) would crash across the port towards the roof and upset this high flow area.
Old Dec 4, 2002 | 11:45 AM
  #63
Guest
Guest
Posts: n/a
Well I've seen lots of aftermarket heads, those the port floor looks ramped up even more than any others I have seen.
Old Dec 4, 2002 | 12:39 PM
  #64
gruveb's Avatar
Car: 1989 IROC-1
Would the height of the ramps have a negative or positive effect on performance?
Old Dec 4, 2002 | 01:03 PM
  #65
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Those heads look a lot like mine. I got the 200cc port 72cc chamber iron heads. FYI, Mark, according to Pro, the 72cc heads flow better than the 64cc heads.
Old Dec 4, 2002 | 01:18 PM
  #66
Car: 99 Formula
Axle/Gears: 342
oh really, where did you find that info , just wondering.
either way, no way could i could use 72cc heads with my dish pistons
Old Dec 4, 2002 | 01:24 PM
  #67
Momar's Avatar
Why not? Then you would be ready for a blower. Seriously though do you know what your compression will be with the 64's?
Ben
Old Dec 4, 2002 | 01:36 PM
  #68
F-BIRD'88's Avatar
Positive... never lower the floor on a intake port.
Old Dec 4, 2002 | 01:39 PM
  #69
Car: 99 Formula
Axle/Gears: 342
Ben
I'll have around 9.2:1 with the new heads and gasket I got.
I'd really like to have 11:1
  #70
99Hawk120's Avatar
www.procylinderheads.com
And, there's no way I can use 64cc on my 406 with pump gas...
Old Dec 4, 2002 | 01:45 PM
  #71
Momar's Avatar
Man thats still kind of low for aluminum heads. You keep talking about stroking it so I guess you can get higher compression pistons when you do that.
Ben
Old Dec 4, 2002 | 01:49 PM
  #72
Marshall89ws6's Avatar
Mark why dont you just get a set of hyperetectic pistons.... flatops with valve reliefs and boost ur comp up to like 10:1-10:5-1. would be like around 300 for them.
Old Dec 4, 2002 | 01:52 PM
  #73
wait i forgot that ur "stroking it" soon heh.... haha i guess u'll get em then
Old Dec 4, 2002 | 01:53 PM
  #74
Car: 99 Formula
Axle/Gears: 342
Yup, I would have by now, if I had a garage or the tools, I should have a shop built by next summer, so hopefully then.
Old Dec 4, 2002 | 02:16 PM
  #75
gruveb's Avatar
Car: 1989 IROC-1
That's what I thought, but I'm an idiot so I thought I'd better ask.
Old Dec 18, 2002 | 01:44 PM
  #76
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
you have to have the bottom end rebalnced if you change pistons...
heads look good mark.. i'll be looking forward to seeing some numbers!
Reddeath210
Oct 6, 2015 08:20 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
MY87LT
Aug 17, 2015 08:43 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
