Stupid Timing Question
Old Dec 1, 2002 | 08:58 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
I have an 85 Berlinetta with the lg4 carbureted engine. I failed MO emissions badly. HCs should be .8 tested 4.6 and CO should be 15.0, tested 130.0. I put on the new AIR pipe to the Converter (it was missing!) and tried to adjust the timing. The tag under the hood says set at 0 degrees, with the 4 wire connector unplugged.
Does 0 degrees sound right? Now the car shudders at take off and then clears out after a couple of seconds. Before it was set by sound and it ran great. It will be moved if I ever pass emissions.
Any help appreciated.
Old Dec 1, 2002 | 09:03 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
yea, 0* is the stock timing for our engines. id advance it after you pass emissions.
Old Dec 1, 2002 | 09:30 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
0 is correct, runs like $hit, but correct (by emmisions standards).
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
gta power
Aug 13, 2015 06:15 AM
