Trying to decide......
Old Dec 2, 2002 | 12:38 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Hey all!!
I'm trying to decide what aftermarket intake to buy. I'd like to get something that will reasonably adapt to what I have now, but also use on a 383 later on.
My engine setup is in my sig. I do plan on getting a Hooker catback exhaust also. The powerband for the cam I have starts at 2500 rpm's I think. Any suggestions from you gearheads appreciated!!!!
Old Dec 2, 2002 | 12:58 PM
Confuzed1's Avatar
Car: 83Z28 HO
BTW...I'm not too concerned about egr either........
Old Dec 2, 2002 | 02:42 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Try a Weiand X-celerator 7546 or 7547 for low rise
Old Dec 2, 2002 | 02:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Weiand Stealth idle-6800 rpms $110 in Jegs.
Old Dec 2, 2002 | 03:58 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
out of curiosity, is there an intake like the weiand stealth that does have EGR??
Old Dec 2, 2002 | 04:28 PM
Momar's Avatar
Will the stealth work with the quadrajet?
Ben
Old Dec 2, 2002 | 05:23 PM
Car: 99 Formula
Axle/Gears: 342
You can make it have EGR. not very hard, from what I've heard.
Old Dec 2, 2002 | 05:53 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is also a Weiand Action Packer intake with EGR I noticed. Check that to see if it'll suit your needs.
Old Dec 3, 2002 | 12:28 AM
Confuzed1's Avatar
Car: 83Z28 HO
I was considering getting a Weiand X-celerator, but I see no provisions for my vacuum tower on the front of my intake. I like the 1500-6500 range it has, and since it's a single plane, I would think it would respond well when I wind it out, wouldn't you think??
Or does the other Weiand Stealth has more provisions drilled into it?? I can't tell by the pics. I know someone on this board has to have one of these intakes. Thanks for the replies....keep em com'in!!!
Old Dec 3, 2002 | 12:31 AM
Confuzed1's Avatar
Car: 83Z28 HO
Also......I'd reeeaaaly like to keep the CCC Q-Jet for now.
Old Dec 3, 2002 | 12:34 AM
curt86iroc's Avatar
Car: 1990 IROC
yea, this seems like a nice manifold.....
Old Dec 3, 2002 | 12:50 AM
Confuzed1's Avatar
Car: 83Z28 HO
Where is this "Action Packer " intake you speak of????
I know Summit doesn't list it...
Old Dec 3, 2002 | 12:59 AM
curt86iroc's Avatar
Car: 1990 IROC
actually, thats where i found it. under air & fuel delivery, then intake maifolds, weiand, the action plus...
Old Dec 3, 2002 | 05:30 AM
Car: 1992 RS
Engine: Carbed 350
Action Packer EGR
http://store.summitracing.com/partdetail.asp?part=8820
Old Dec 3, 2002 | 07:32 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I have the Weiand Action Plus intake and it seems to be pretty good. Slightly less rpm range than the Stealth. I believe you can get it with or without egr and your cc quad will bolt right to it.
Old Dec 3, 2002 | 12:57 PM
Confuzed1's Avatar
Car: 83Z28 HO
Ohhhhh....The Action PLUS intake....
You threw me for a loop with the Action Packer thing. I thought maybe you guys were trying to make a crack on the fact that I'm in Green Bay Packer territory!!
Yea, I've looked at the Action Plus, but it seems to be one of the milder intakes, but I don't know for sure. I like the fact that my Q-jet will bolt right up though.
The reason I was looking at the accelerator so hard was because of the RPM range (1500-6800), which appears to be a better match with my cam. Do you think??
Anyways, that may be a moot point if my Q-jet won't bolt up to it, along with other connections. Anyone else???
Old Dec 3, 2002 | 03:53 PM
Car: 1992 RS
Engine: Carbed 350
LOL ... sorry ... packer/plus - a little foggy in the noggin this week.
Old Dec 3, 2002 | 04:58 PM
gruveb's Avatar
Car: 1989 IROC-1
I have an Action Plus on my 305 L69. I have an edelcrap 600 carb, a Comp Cams XE 262 cam, roller rockers and other junk..blah blah blah, anyhow, I am very pleased with the intake. I'd buy it again anyday.
One thing I noticed is that if I went with a larger intake, even a little bigger I would have to have such a small filter that I would lose power b/c it would be too constricted.
I'd suggest it anyday. I can't say over the Stealth or not, but I rev to 6,000 rpm easily, no problems at all.
Besides, it's a big "YAWN" to open a hood and see all Edelcrap in there. Although, I have to laugh at myself, I have edelcrap carb and valve covers...............but only because I had little money at the time and they were the cheapest I had available at the time.
Old Dec 4, 2002 | 12:41 AM
Confuzed1's Avatar
Car: 83Z28 HO
Hey Gruveb -
That's good info....
Good point. I'd like to keep the duel snorkle on mine. I plan to buy a 2 1/4 inch cowl hood in the near future, but not really for clearance issues- just cause I like how it looks.
Still using the computer myself. Not a big fan of Edelbrock carbs though. I had a performer years ago on my 72 Charger, and I couldn't tune it right to save my a**.
But I hear many people like them here. Glad to hear you like the intake. We have somewhat simular setups - but could you tell me if it has enough vacuum ports, like for the tower up near the T-stadt housing?
BTW.....first it was the Packer thing, and now the blah,blah thing like in my sig?? Or am I just paronoid?
Old Dec 4, 2002 | 07:29 AM
Momar's Avatar
yup they are picking on you because you have a ford in your sig. j/k
Ben
