How Do You Burnout?????
Old Dec 2, 2002 | 10:15 AM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
I know how to burnout by dropping the clutch at a higher RPM, but how do you sit there and burnout for as long as you want? i.e. huge smoke clouds, etc.? Thanks
Old Dec 2, 2002 | 10:20 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You have to be really good with your feet to do it with a clutch.
I've never really tried it, then again only stick cars I've had were 4 banger Stangs.
Old Dec 2, 2002 | 10:25 AM
F-Bodeee's Avatar
can't i just
I thought it was something with the e-brake? is it? or is that just automatics?
Old Dec 2, 2002 | 10:33 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
mash gas, dump clutch, slam foot on brake, as fast as you can... simple
Eric
Old Dec 2, 2002 | 10:48 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
let the fluid out of your back brakes..
or get a line lock.
I sorta need a reverse line lock.. with the cold weather.. the nittos just roast in first and second.. and still part of third.
Old Dec 2, 2002 | 10:55 AM
camarokev400's Avatar
easy..... put your heel on the brake toe on the gas and give her some gas and drop the clutch, hold the brake and watch the smoke fly then get the hell outta there
Old Dec 2, 2002 | 11:00 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
good tires are very expensive...
Old Dec 2, 2002 | 11:01 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Re: can't i just
Not an automatic tranny thing, that's a front-wheel drive thing. The e-brake locks up your rear tires, so it helps do a burnout in a FWD car.
Old Dec 2, 2002 | 11:22 AM
ede's Avatar
ede
mash brake, engage line lock, release brake, mash gas
Old Dec 2, 2002 | 11:59 AM
MdFormula350's Avatar
first gear, hold brake, slam the gas, and just let off more on the brakes..
Old Dec 2, 2002 | 04:06 PM
Jza's Avatar
Jza
Step 1: Install big block, mash gas, replace tire.
Step 2: Install posi, mash gas, replace tires.
BTW: Heel on the brake toe on the gas? I gotta switch from boots to shoes.
Old Dec 2, 2002 | 04:24 PM
LOL yeah boots wouldnt cut it... def needs shoes our pedals are too close together for big boots
Old Dec 2, 2002 | 04:25 PM
Momar's Avatar
This is one of those things I figured out on my own pretty much like anything else that was able to get me in trouble. I always just used one foot onthe gas and brake and the other on the clutch.
Ben
Old Dec 2, 2002 | 05:36 PM
rjmcgee's Avatar
When I was young and stupid I owned a 83 rx7. The only way to get good smokage action was to haul *** backwards, shove it in first, and dump the clutch at 6000 rpm.
Otherwise known as reversage, driveage, burnage.
Relaced the clutch soon after.
Old Dec 2, 2002 | 06:15 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
So what's the steps with an auto? Can it be done like that?
Old Dec 2, 2002 | 06:19 PM
Momar's Avatar
Gees... Auto is simple. Hold the brake and give it gas. Just give it enough brake you dont move because the harder you press the brake the harder the rear wheels have to try to spin because of the rear brakes.
Ben
Old Dec 2, 2002 | 06:26 PM
Davidgou's Avatar
Should I shift it to 1? or can it also be done in OD?
Thanks by the way.
Old Dec 2, 2002 | 06:38 PM
Momar's Avatar
I usually used drive. Just a warning though. THIS IS BAD FOR YOUR CAR in more than one way. It wears on your tires(obviously) and rear brakes, and can really heat the tranny up which is not good for it. I have done it many times in the past though.
Ben
Old Dec 2, 2002 | 07:05 PM
PhilM's Avatar
Car: Accepting applications...
You poor kids that never burned tires before really need to get out and start doing it. Life is so beautiful when you are sitting there on a dark road with screaming rubber in your ears, and smoke rolling into the car....
I think everyone covered all the good points. Took me a few years to get really good with the stick, but now it is like second nature.
After years of burning rubber with my beast, I have been through countless axle seals, rear brake pads, and of course tires. I also broke the backing plates for my rear drums, twice. There is about 1/16 of an inch of tar and rubber permanently stuck to the OUTSIDE of my wheel wells.
If you burn alot, you will need to scrape the rubber out of the inside wheel wells on a regular basis.
I offer free burnout lessons in front of my house for all those interested.
Old Dec 2, 2002 | 07:26 PM
Momar's Avatar
lol
Old Dec 2, 2002 | 07:58 PM
Bort62's Avatar
Helllo Oklahoma!
yeesh....
Abubaca
Nov 5, 2016 12:22 PM
Thirdgen89GTA
Apr 11, 2016 02:07 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Cleotiz
Sep 16, 2015 08:02 AM
Amillionoh7
Sep 5, 2015 11:44 PM
