View Poll Results: what should i do? (college budget rules apply)
fix this engine (on my own)
33.33%
replace with a 350 (on my own)
40.00%
have a mechanic fix this engine
6.67%
have a 350 installed
20.00%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
the horrible 305
Old Dec 2, 2002 | 10:17 AM
dbarker02's Avatar
the horrible 305
ok heres the deal. maybe some of you rememebr my summer of torture, maybe you dont.
Over the summer i pulled the roasted 305 outta my 84SC, & replaced it w/ a quick swap, an 85 caprice 305. dead straight hookup cause it was identical.
This engine runs but the car is still not drivable. the engine *chugs* a bit & backfires a lot. It runs just well enough to say it runs but put a load on it (put it in gear) and bam... it dies.
So, this all said is there something i need to do to get it going?
If anyone has some ideas im open to em. Im probably just gonna send it to a mechaninc, but if someone can get me the info of what is wrong ill do as much as i can on my own... much much cheaper that way. Thanx guys.
:rockon: :hail: Rock on, burn rubber & hail the greatness that is our cars!
Old Dec 2, 2002 | 10:23 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is it carbureted? Check your timing and choke.
Old Dec 2, 2002 | 10:28 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
It sounds like your distributor might be off by one tooth.
Old Dec 2, 2002 | 10:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You have a fuel delivery issue. Leave the timing and the EGR alone, and don't rip all the smog stuff of just yet either. The favorite non-tech newbie buzzwords won't help you in this case.
Sounds to me like maybe the carb needs a rebuild in the worst possible way. Well, not the worst possible rebuild, but.... you get the point. Or, if you have both carbs, you could test this by swapping them.
You might want to at least try the fuel filter first, in the fuel inlet nut. Use a 1" wrench to hold the big nut still, and a 5/8" tubing wrench to loosen the nut.
It nay also just need a fuel pump; or if you did anything to the front of the motor like bracket swaps or anything, check the upper bolt that holds on the smog pump bracket, on the pass side of the front of the motor. That bolt goes directly into the fuel pump rod's hole, and if the bolt is too long, it will lock the pump rod in place, or at least severely restrict its motion. Put a short bolt in that place, no longer than 1".
Old Dec 2, 2002 | 07:41 PM
dbarker02's Avatar
hmm.. time to clarify i guess
lets put it this way.. it runs really really well once you get the revs up past the chugg stage. it idols extremely well too. however the second you hit the gass or give it the load.. it goes to the good ole steam engine setup & hit crawl home mode. get the idea? thanx.
Old Dec 2, 2002 | 07:51 PM
gruveb's Avatar
Car: 1989 IROC-1
Do a tune up! Worse case scenario you'll have at least solid ground to start working on, and you'll eliminate some possibilities.
But definitely don't just throw a new engine in there b/c of this. Chances are if you can't get this one running you will have similar trouble with another. It's a tempting thought to just start over, but sooner or later the same old problems will crop up and you'll be right here again!!
Old Dec 2, 2002 | 07:55 PM
Bort62's Avatar
Listen to RB.
I am also inclined to belive you may have a timing problem. Make sure you set the timing with the EST disconnected.
You did set the timing, right ?
Old Dec 2, 2002 | 08:07 PM
dbarker02's Avatar
well....
lets see... timing... you know, i may not have.. i worked for 3 days straight on that thing ( 1st swap ever) & i didnt sleep till it started up... so i may not have done it.. then again i might have... ill look into the timing issue... after that what should i check on? the fuel system is fine.. i know it is.so where to from there? thanx everyone.. its helping a bunch.. i just have to wait 2 weeks to find out what it is... (i cant get home for 2 weeks so im stuck at school......)
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
