horsepower on an old truck engine?
Old Dec 2, 2002 | 06:41 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
does anybody know how much horspower a stock 350 from an old 3/4 ton truck makes? and then after you port the heads, add a cam, performer intake manifold and 600 cfm performer carb and maybe some headers? thanks alot
Old Dec 2, 2002 | 06:43 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Not totally sure, only bad thing being a truck motor, it will prolly have very low compression.
Old Dec 2, 2002 | 06:56 PM
bad_ta_05's Avatar
Car: 85 trans am
whats a good way to raise compression?
Old Dec 2, 2002 | 06:58 PM
Car: 99 Formula
Axle/Gears: 342
I assume most truck engines came with dished pistons, if so, changing them would be one of the best ways, also getting a lower cc head. Like from a 305 if you're tight on cash.
Old Dec 2, 2002 | 06:59 PM
bad_ta_05's Avatar
Car: 85 trans am
that would probably work out well then because i am swapping for a 305, so if i ported the 305 heads and put new valves and springs in the 305 heads would this work?
Old Dec 2, 2002 | 07:02 PM
Car: 99 Formula
Axle/Gears: 342
I don't see why not, long as you don't have L03 heads you'll be fine.
Follow the porting directions in SittingBull's sig.
or here is a helpful link.
http://www.babcox.com/editorial/us/us110128.htm
Old Dec 2, 2002 | 07:05 PM
gruveb's Avatar
Car: 1989 IROC-1
What year is the truck? Before I'd start tearing into it I'd figure out what you have exactly.
Mark is probably right though, they usually had very low compression.
Old Dec 2, 2002 | 07:08 PM
bad_ta_05's Avatar
Car: 85 trans am
its a 79, im just considering buying it, dont have it. and my engine is an lg4 with 158,000 miles and it just took a crap on me, so i would probably have to rebuild the heads if i used them
Old Dec 2, 2002 | 07:13 PM
gruveb's Avatar
Car: 1989 IROC-1
79 isn't a banner year I'm sure. I don't know the exact numbers, but I'm sure they're not too exciting.
Doesn't matter anyway. If the engine is cheap it doesn't matter as long as it is usable.
Old Dec 2, 2002 | 07:15 PM
bad_ta_05's Avatar
Car: 85 trans am
thats true, and i figured its a 350, more power than my lg4 any way u look at it, and after a few mods im hoping it will go pretty good
Old Dec 2, 2002 | 08:16 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Car, truck, doesent really matter compression wasent whoopty in most cars or trucks 73+. Remember having high compression doesent always mean high HP, it just means every time you fill up you pay more for fuel. If I remeber correctly my 76 CA truck was actully the highest rated 350 with a whoping 175/180HP. The same rule as any engine, heads, cam induction and exhuast = HP But this isnt a bad platform to start from.
jhawkeye
May 25, 2022 06:33 PM
junkcltr
Aug 2, 2019 11:12 PM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
