vette heads vrs after market
Old Dec 2, 2002 | 12:47 PM
SlowMaro's Avatar
sorry for glogging up the board guys, i just need an over all plan of what im doing before i buy stuff im not gonna use. i was going to go with the world products torquer heads, then thought about the vette heads.....which is better ? also...should i just bow down and swap to carb ?? or work with the tbi <millions of you will say tpi but blah, too much calling junkyards> anyways, ...everyone put there 2 cents in here, this way i can get a good idea of wtf im doing in the long run. help! lol
Old Dec 3, 2002 | 02:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Aluminum L98 heads, although they have 58cc chambers, will represent a loss of compression on a 305. That's due to the higher heat loss through the aluminum, which not only allows but requires a higher static compression to make up for that heat loss and maintain power output. So, if used on a 305, they should be shaved down to 52-54cc, which will probably require shaving the intake manifold as well.
The World S/R Torquer 305 will flow pretty much the same as unported L98 heads. They'll flow even better if treated to a pocket porting job prior to installation.
Either way, the TBI can be made to run. For more info on that, talk to the guys on that forum.
Azrael91966669
25
Jun 20, 2017 04:04 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
Americanmouse
Sep 7, 2015 12:10 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
