Does GM make wire harness extensions?
Old Dec 6, 2002 | 09:11 AM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I have a 92 w/ a 3.1 in it and I was wondering if GM made wire harness extensions so that I can move my airbox sensor to the center of the car without having to cut the wires. I want to convert from the tube intake to the iroc intake, thanks.
Old Dec 6, 2002 | 09:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
No, but you can easily make your own. Get a male & female plug from a junk yard car or from a local parts store, get the proper pins at a local parts store, and get some wire. You can whip up your own in a couple hours.
ede's Avatar
ede
not that i know of, i believe you'll have to cut the wires.
Old Dec 6, 2002 | 10:13 AM
Thanks guys, your answers were short, and what I needed. I guess I'll have to accept that they dont make them and I will probably go to a junkyard and get one.
Old Dec 6, 2002 | 10:20 AM
Jza's Avatar
Jza
Actually, have you ever taken apart a TPI unit with the MAT sensor underneath the upper plenum? The lead that goes to that is an extension. In other words, it can unplug at the trunk of the harness OR at the sensor itself. I believe that was to facilitate the removal of the plenum. Anyway, that should be the same connector, no?
I have one in a box, I'll take a picture of it tonight.
Of course, it's only a foot long, but it would be easier to cut and extend than your car's harness.
Old Dec 6, 2002 | 11:56 PM
sounds good, its a basic two prong connector that is used throughout various engine electrical components
Old Dec 8, 2002 | 12:33 PM
Vader's Avatar
PimpRod,
The exact locations will probably be different on your car, but I've got all the part numbers and instructions here:
MAT Sensor Relocation.pdf
You can get the parts almost anywhere and won't need to cut ANY wires in your OEM harness.
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
