different size plug wires
Old Dec 6, 2002 | 01:33 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
I just got a new set of plug wires for my car. But something was messed up and half are 7mm and 8mm. I needed to use the car today so I ran it with the different size wires. The car ran good for about 30 seconds, then it started shaking real bad. Like taking off then stopping then taking off again almost stalling. Is this from the wires? Or did I F something else up?
Old Dec 6, 2002 | 03:14 PM
Vader's Avatar
Mix all you want - 6, 7, 8, 8.5mm - it doesn't matter as long as the insulation on all of them is good.
I'm betting that something else is the main problem, unless some of those "new" wires were not any good. If the set is mixed,it may have been returned, and some less-than-scrupulous individual may have swapped a couple of old, dead wires into the set.
Old Dec 6, 2002 | 03:58 PM
Killogy's Avatar
Engine: 355
Well I'm gonna go exchange them tomorrow for a correct set. So I'll see if thats the problem.
Old Dec 6, 2002 | 05:10 PM
MikeS's Avatar
I've had to mix brands before (some Accel with some Napa or something). The car ran terrible. It stumbled and shook and jerked and I was convinced I had some other problem. Since I knew I had to do something about the wires, anyway, I bought a set of MSDs, cut them to length, and crimped them. That fixed the problem completely. So, my opinion is that if the car ran ok before mixing the wires and ran bad once you mixed the wires, it will run ok again once you put on a set of matched wires.
Now, there could actually be bad wires in there like too. I hate to come on here with an opinion different from Vader since I know he has helped me before.
Old Dec 7, 2002 | 08:40 AM
Vader's Avatar
Originally posted by MikeS
...I hate to come on here with an opinion different from Vader since I know he has helped me before.
Hey, Mike!
Somebody has to keep me honest. There are a lot of possibilities, and you may very well be right. I was only pointing out that in theory, a set of good wires shouldn't make an engine run roughly. It's more likely that there is another problem, or one of the "new" wires isn't a good one (or possibly fell off or shorted to the block). Even a new set of MSDs (and MSD is good wire) will have different resistances and inductances as a result of their varying lengths. I do know that some of the newer DIS ignition systems with shared coil packs can be sensitive to plug wire length/inductance differences, but I'm guessing that this isn't his type system.
Old Dec 7, 2002 | 08:51 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most likely you have a boot that is not all the way on at one of the plugs. Wire length is inconsequential with most ignition systems assuming all the wires are connected.
Old Dec 7, 2002 | 12:49 PM
Killogy's Avatar
Engine: 355
It's not the length of the wires that was different, it was the width, some where the stock 7mm and others were 8mm, but one of them came dissconnected from a plug. I haven't tried the car since i put it back on since I'm getting a new set today anyway.
Old Dec 7, 2002 | 07:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah, most V8s don't run too well on 7 cylinders
Old Dec 8, 2002 | 07:30 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
I meant width, just goes to show what that first cup of coffee or lack of it does to my thought process. Either way it does not matter at all, something else is going on and you'll most likely correct it by going over it again.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
