leaky oil plug??????how bad is this?
Old Dec 6, 2002 | 08:26 PM
squirrelybird's Avatar
hmmmm...i'm a bit worried...it seems my oil plug is starting to leak just a little. it didn't used to at all, and i stress this is small...i don't lose much oil at all, but the oil plug is a little "damp" with oil, as if it is "trickling" out<-----seems as if the plug isn't making a good seal.
should i just get a new oil plug, or is my problem gonna be bigger than that??
Old Dec 6, 2002 | 09:09 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
They have a actuall gasket for the drain plug itself. You should be able to buy these at your local automotive store. That should fix you up. But a new plug isn't that much $$ anyway. Not a huge thing to worry about, just replace it and off you go. That is as long as you are sure it is the plug. Go get your Oil changed at Walmart and they probably have one right there for you.
Old Dec 7, 2002 | 08:52 AM
Vader's Avatar
Depending on the year and engine, you may have a plain steel drain plug that used a nylon washer to seal, or you may have an undercut plug with an 'O' ring seal. The next time you change your oil, take a close look under the head. If there is on groove or 'O' ring, you need the nylon washer. If there is a ring, inspect it closely for damage.
Old Dec 7, 2002 | 12:19 PM
hmm thanks guys, sounds good.
i have a 91 3.1 firebird, if that helps.
i think ill just buy a new plug....are they all the same size??
Old Dec 8, 2002 | 05:38 PM
Marc 85Z28's Avatar
Just adding that if you do have the separate nylon washer style... Throw it away. It will always leak a little. Go with the newer style O-ring plug.
Old Dec 9, 2002 | 09:24 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
yeah i agree......just get a new plug. Make sure that the pan hole isnt stripped.....
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
