Why are there different part numbers for vette and fbody TPI gaskets?
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
nt
The reason im asking is because I got a gasket set for my fbody L98 but I put vette heads on the new motor and I have vacuum leaks at every intake port. Are the lower manifold gaskets different or are there other pieces in a vette set? Thanks
Felpro part number for the vette is MS93318 and for a fbody is MS93035-1. The upper only set is the same part number being MS93160.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I think some of the vette l98's had the older style intake face but im using the gaskets for the f-body L-98 on my pre 86 motor with no problems. theyre all the same. Who makes the gaskets? I have the felpro ones and they work great.
Car: To many to list
I would think that they are different.Each one is made to match either the cast or alum head.When you got the head gaskets,did you get ones for the alum heads?
Car: 88 Camaro SC
Engine: SFI'd 350
steve did bring up an important point, some gaskets have inadiquate crushability so they wont seal properly.
Thanks, ill get the gasket set for the corvette aluminum heads and I hope that will fix my massive leak. The leak combined with my hot cam leaves me is little power brakes.
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Two things. All L98 vettes have the older pre-87 intake bolt configuration, so this could be a problem when you're looking for gaskets for an '87-later f-body tpi engine. Also, the aluminum heads on vette L98's don't have a heat crossover (EGR passage) like the standard iron tpi heads. They have some kind of plumbing from the exhaust manifolds directly to the intake for the EGR function.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
check out http://www.tunedport.com/ there's some good info there on this.
1992 Trans Am
May 10, 2023 07:19 PM
