2001 buick regal question
Old Dec 8, 2002 | 07:28 PM
jase's Avatar
My wife's car has that antifreeze smell coming from under the hood.It's not running hot,no water in the floorboard,and no leaks on top of the motor or hose.Why would this smell be so strong?
Old Dec 8, 2002 | 08:58 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
check the intake manifold for leaks! the hardest one to see is under the throttle body the rubber gasket leaks just enough were you can smell it like that it can drip on the trans housing and dry up befor it makes it to the ground. till it gets bad then you will see it plane as day
Old Dec 8, 2002 | 10:00 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yeah, i've seen the 3.8L plastic intakes leak right under the throttle body. It's hard to see. Those intakes get brittle after having coolant run through them and they crack.
ex-x-fire
Jan 12, 2024 01:58 PM
neilb
Oct 4, 2018 12:36 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
