Ignition module blew again! I am forced to replace my ECU
Old Dec 9, 2002 | 10:19 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
My 4th ICM has now lasted 48 hours before the camaro put it to rest. I feel that it is the ECU that is sending the spike to kill it. I heard that from some guy, he said he replaced his and it was fixed for good. Now I wanna know should I spend the 100 bux on a new one, I dont feel like taking this to a mechanic for him to charge me to find something out that i can on my own. The funny thing about it dying is, they usually last about a month before dying, this one died in two days. Same make, same everything. I did use the white crap, so that is ruled out. I went to check my external coil with my ohm meter yesterday and i had to disconnect my wires of the coil to do so. So could that have meant that it was my coil that killed the car? I drove it to work yesterday after I put all the wires are in, so thats ruled out also. What is it, I want a quick easy fix. Im the only kid in my school w/ a car that breaks down, and kids even have 87 camrys and 84 volkswagens.
Old Dec 9, 2002 | 11:04 PM
89IRO's Avatar
Do you have any aftermarket ignition parts. (aftermarket cap/rotor, coil, module etc.?) Or is you whole iginition stock? -89IRO
Old Dec 10, 2002 | 12:26 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
My old taxi used to eat modules. It turned out to be the Canadian Tire el cheapo modules were made in Taiwan and they left out certain parts when building them, thus the cheaper price.
Finally, I bought a Blue Streak module that was twice the price ... but never fried again
Old Dec 10, 2002 | 08:06 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
OMG, i actually agree with sitting bull on something.
Have you purchased all of the modules form teh same store, and are they some generic brand? If so then yes i could believe 4 of them failed like that in short order, could easily be a junk supplier. I don't think i've ever seen a generic module last for more than a short time, or work effectively for performance anyway.
If they are good modules (i forget off the top of my head what would be OE, maybe borg warner?) then maybe it is something weird like the ECM but the only way to find out would be to replace it and cross your fingers.
Old Dec 10, 2002 | 08:13 AM
gruveb's Avatar
Car: 1989 IROC-1
I went through enough modules to fill a Christmas stocking before I broke down and bought an Accel. Certainly NOT the most expensive out there, but it's been trouble free for about 2 years now!
Old Dec 10, 2002 | 10:43 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I went through 4 cheapo's before getting the Borg Warner one myself. Has lasted for 2 years now. Spend a few more dollars and get a good one.
Old Dec 10, 2002 | 10:59 AM
gruveb's Avatar
Car: 1989 IROC-1
That's funny. Borg Warner is one of the brands I was blowing up regularly!
Old Dec 10, 2002 | 11:38 AM
Im running the borg warner iCm on a bone stock ignition. Its been blowing them out left and right and they are 60 bux a pop. like i said, time for a new computer? this brings up a good hypothesis
Old Dec 10, 2002 | 11:41 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
It is weird. I dunno, I've never really had a problem with Borg Warner parts. Of course you cant really go wrong with caps/rotors etc... Anyone else?
Old Dec 10, 2002 | 04:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Trying to remember what I read in my manaul, but low resistance in some part of the circuit could be the issue. I don't think it's ECM related. If I've time when I get home tonight, I'll find what I read and repost.
Also, you are using the goo under the module when installing it?
Old Dec 10, 2002 | 04:31 PM
Yeah Im usin the goo, might replace a lot of stuff under there, all of which is connected to the module.
Old Dec 10, 2002 | 05:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'll bet the coil is the problem. Replace it & the module both at the same time. Bad coils are notorious for taking out modules.
RBob.
Old Dec 10, 2002 | 08:05 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Ignition pickup coil is another thing that can cause problems with modules.. Sometimes when you have a vehicle thats killing modules you just need to break down and replace both at once.
Old Dec 10, 2002 | 08:10 PM
gruveb's Avatar
Car: 1989 IROC-1
Always a good idea to check both, but that wasn't the case in my situation.........I tried swapping both.
Mine was all the module!
Old Dec 10, 2002 | 09:12 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
Is the pickup coil the same as the ignition coil?
Old Dec 11, 2002 | 01:13 PM
The pickup coil is inside the distributor right near the Ignition Module. I dont know what it does, but it has two thin wires going into the icm, opposite the end of the ignition coil. I believe the pickup coil tells something to the ignition module, and the ignition module tells the coil when to spark. Anywhoo, they are two different things in different places.
Old Dec 11, 2002 | 01:15 PM
by the way, what could make my computer do this? I replaced my ECU last night, and my car starts better, like brand new, and everything seems to have more power to it. Maybe my subwoofer and amp are drawing too much power or something.
Old Dec 11, 2002 | 09:08 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The pickup coil is what tells the ignition when to fire.. the ignition module is actually a signal amplifier. With ecm controlled distributors its slightly more complicated.. the module amplifies the pickups signal and sends it to the ecm.. The ecm then sends it back, but varied for timing, the module then amplifies again and sends this signal to the coil.
Old Dec 11, 2002 | 09:28 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
By what other names do they call pickup coils? I can't find them listed on jegs or summit.
Old Dec 11, 2002 | 09:32 PM
gruveb's Avatar
Car: 1989 IROC-1
I thought that pick up coil and coil are the same exact thing, but lingo is lingo..........or maybe it's not.
BRoss99
Aug 10, 2025 05:08 PM
IroczFan
Oct 6, 2015 10:13 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
