what heads do I have???
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
which heads are these, and what is the flow? thanx
14101081
14102193
which one is better? is it worth rebuilding, or just go buy vortec heads?
14101081
14102193
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Engine: T.P.I L98.
Transmission: TH350
OK...Umm well off hand I am unsure, but someone here will know for sure, just going to have to wait for that one person. Vader is the most likely candidate to answer this question, he is very knowledgeable with this stuff.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
From a budget hi performance build up point of view
the 081 heads are better than the 193 heads.
The 193 heads are "swirlport heads" They don't respond well to porting. They have a funny shaped port, designed for high swirl on a low performance motor. This shape limits the amount of flow but enhances swirl. They have limited hi performance potential. If your looking for more horsepower, forget these.
On the other hand the 081 heads are one of the best
late stock heads to start with for a budget hi performance build up. The have full sized ports that respond well to porting and upgradeing with bigger valves. They have a well shaped compact combustion chamber that makes it easier to get a decent finished compression ratio on either the 350 or 305. They have 58cc chambers but will end up being about 61 cc's once you relieve the chambers for larger hi flow 1.94 x1.60 valves. You can shave them down a bit to restore the 58cc chamber size if nessessary.
It all depends on how much work your willing to put into
them. The potential is there. They need a thourough porting and the larger valves. If thats just not your thing, then get the vortecs. They work well. You won't be disappointed.
so then which do u figure is better 081 or vortec, keeping in mind saving money is always a good thing.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
