Can you ID these headers?
*reposted to get answer in time....sorry and thanks*
Here they are. Dude selling them claims he doesnt even know what brand or model they are!
They are 1 5/8 primaries and 3" collectors.
Car: 89 IrocZ
Engine: L98-ish
Well, can't help "what" they are, but can tell you this...no AIR tubes...means no EDO number for smog...means no passing the visual until you reinstall everything you took off.
I I'd pass on'em
I I'd pass on'em
You really sure those are f-body??? The space inbetween the primaries on the pass side headers doesn't look right for how tight they fit in there. I have a set of heddman long tubes and those are not them. brad
Well, no I am not sure. The guy claims they are for 82-92 FBody. But says he honestly doesnt know what brand and has had them 4 years..... hmmmm..
I know, I know, I know that it wont pass CA smog. But it wont be smogged so I do not care.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
just for the record, edelbrock tes headers for the G-body are the same as the ones on a thirdgen. the only difference is the Y pipe. i assume that other header kits are the same. for instance you could put SLP headers on a G-body wiht a custom Y pipe.
Car: 89 IrocZ
Engine: L98-ish
Heck, if you're not concerned about smog, and this guy really isn't sure what he bought new 4 years ago, I'd spend a c-note on a set from Summit, ask for the 10% discount they have through the end of the year, and start with something new that you know will fit your car
Car: 86 IROC
Engine: 383
good call madmax. the more i look at them, especially the passenger side header, that wont fit on a thirdgen or an G-body. that rear primary tube will hit the heater box on a thirdgen for sure. my TES headers are bent as close to the engine as possible back there. on those headers the #8 primary comes out over top of #6 primary. there is almost no way that would fit a thirdgen engine bay.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Originally posted by 88 350 tpi formula
they look like G-body ones or something like that!
Engine: T.P.I L98.
Transmission: TH350
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
look just like the flowtechs i had on the elcamino before i sold it
redformula88
Oct 14, 2015 06:08 PM
