Disconnected the alternator...
Old Dec 11, 2002 | 09:25 AM
SoSoFresh_SS's Avatar
Car: 1984 Firebird
Engine: 2.8L V6
I disconnected the alternator while the car was running and it didn't shut off. So that tells me my alternator isn't bad. My battery is new. What else could it be? I can drive my car all day if I dont turn the lights on. Soon as I turn my lights on my car wont start back up. Since its not the battery or the alternator should I take it to an auto electric shop? Or should I check something else first?
Old Dec 11, 2002 | 09:28 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Disconnected the alternator...
I've never heard of that one before.
Old Dec 11, 2002 | 09:29 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Que?
So if you turn the lights on, the car dies, and then won't restart till the next day? Thats certainly a weird problem and don't even know what i'd begin to check. But something that weird could only happen in a british car (MG, jaguar, etc) or maybe a Ford. Never seen a GM electrical system go that crazy. Perhaps you're not explaining clearly?
Old Dec 11, 2002 | 09:35 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Did you disconnect the alternator or the battery??? If you are having a electical problem that is causing the battery to die, take off the power lead to the BATTERY when the car is running. If it stays running the alternator is fine, if it dies the alternator is finished. Also check you voltage with everything connected properly and see what you get. It should be around 13.5 volts, give or take .5v.
I corrected the "of" to "off"
Old Dec 11, 2002 | 11:11 AM
82-T/A [Work]'s Avatar
No, it should be the other way AROUND...
you test the alternator by disconnecting the BATTERY while the car is on.
If the car continues to run, then it means the alternator is good.
Old Dec 11, 2002 | 11:14 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
That's what I said. Or were you refering to SoSoFresh_SS??
Old Dec 11, 2002 | 11:20 AM
Yeah, SoSoFresh_SS.
Old Dec 11, 2002 | 11:25 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
That's what I thought but wasn't sure.
Old Dec 11, 2002 | 06:10 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
make sure that you dont have any fraided wires or any shorts at all causing it to get grounded or anything where your lights are cause that might do it too. I had kinda the same prob. My rear degfogger plug that attaches to the gas shocks which holds the hatch up...well one of them was not in all the way so when i turned the defogger on it would short out causing the car to stall.....drove me nuts still i found out what it was.
xodus2002
Jul 17, 2020 09:08 AM
gta892000
Aug 11, 2019 11:16 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
