400 compression ratio?
Old Dec 12, 2002 | 07:15 AM
black83z's Avatar
What is the compression ratio of a 400 with stock bore and 882 heads? Thank you
Matt
Old Dec 12, 2002 | 07:47 AM
boogie's Avatar
That would depend on the pistons.
A 76cc chamber head, .038 thick gasket, uncut deck and 12cc dish pistons will give you a CR of 9.0:1.
Using a typical flat top 4 relief piston will increase the CR to 9.5:1
Lonnie
Old Dec 12, 2002 | 07:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
all stock? most are 8.5:1
Old Dec 12, 2002 | 07:07 PM
black83z's Avatar
Thankee all, its much appreciated.
Matt
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
