Autometer electric speedo in a cable driven car?
Old Dec 12, 2002 | 10:08 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I did a search and did not come up with any exact answers. Just wondering what i need to get it done. Do i need to change the VSS and add a buffer box from a late model camaro, 89-up i am guessing!?!? Any help would be cool, thanks. In the search i found that Deadbird, Vader, KarpsT/A, and JZA are all pretty good on this subject. I saw a lot of newer guage clusters going into earlier model cars but no autometer installs. I have seen pictures before but no explanations. Thanks for your time-Bryan
Old Dec 12, 2002 | 04:23 PM
Vader's Avatar
Is this going in your '86? If so, there is already a VSS that outputs 4,000 PPM (Pulses Pulses Per Mile, not parts per million).
If not, you'll have to install a VSS and unless the autometer has a buffered input, you'll need to wire a buffer module. They are available from auto recyclers from '86-up TPI cars, '88-up for other cars. (I think I have a spare around here somewhere in case you run into real trouble.) You'll have to provide a separate 12VDC ignition-switched source.
If you're lucky, the Autometer unit is very forgiving and will accept the raw VSS signal.
Old Dec 12, 2002 | 11:21 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Hey Vader, thanks for replying! Well, Deadbird helped me out a bit in the Electronics forum so i am a little better off now than before. I am going to try and go with the AutoMeter sending unit. It screws right into the trans and it should act as a buffer i guess. I gave a pretty detailed description over on the other board! Sorry, but if its not too much to ask, could you check it out and give me your input? If not, thats alright too! I think you are right about the Auto Meter sending unit though, it should be fine. The guy on the other line seemed pretty confident about it working with just that. We'll see. Well, thanks for your time-Bryan
Jorlain
Aug 24, 2022 05:11 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
beachrodder
Aug 7, 2015 04:27 PM
