new alt reading 8v
Old Dec 14, 2002 | 04:51 PM
SLOW91TA305's Avatar
new alt reading 8v
This is the 3rd alt I put into my car. I took it back and they tested it, said it was working. But in my car it reads 8v.
Can there be an electrical problem elsewhere draining all the power?
Old Dec 14, 2002 | 05:06 PM
Vader's Avatar
Slow,
If you are using the dash-mounted voltmeter to analyze the problem, you shouldn't. Use a separate handheld meter to check the alternator's output voltage at the stud on the back of the unit.
Old Dec 14, 2002 | 06:22 PM
i was using a voltmeter
Old Dec 14, 2002 | 07:47 PM
Vader's Avatar
If you're using a separate (calibrated) meter, you should check for belt slippage, low RPM (underdrive sheaves or low idle), poor ground connections, failing field connector, or a shorted cell in the battery.
Try disconnecting the battery after it is running to see if the voltage increases.
Test maximum output by grounding the test tab through the hole in the rear alternator case:
Do this only long enough to get a voltage reading. You should be able to produce 17-18 VDC or more. If so, the alternator is O.K.
Test teh voltage at the field connector with the ignition on and engine off. Onc of the terminals should have battery voltage.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BDR
Nov 7, 2015 03:05 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Slush92RS
Sep 2, 2015 08:56 PM
