Difference between timing covers for 1 and 2 pc seal?
Old Dec 17, 2002 | 12:31 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Are the timing covers different for the 2 different styles of rear main seals? I'd like to get a 2-piece timing cover but can only find the cheap ones for older style blocks. I would think the older ones would work for all but the newer ones wouldn't work with a cam tab, etc? Trying to get everything for a new engine and want to make changing the cam easier down the road.
Old Dec 17, 2002 | 01:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, the RMS design doesn't affect the timing cover.
The issue that's different, is that AFAIK no aftermarket timing covers come with the welded-on tab for the 12:00 timing mark (typical of newer stock applications), they only work with bolt-on tabs for the 1:30 timing mark. They'll still fit, you just won't have a mark.
Old Dec 17, 2002 | 03:39 PM
Engine: LS7
Thanks I think I can work around that minor problem then. I kinda figured it was something stupid like that.
Old Dec 17, 2002 | 04:12 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
My idiot self thought that when I needed to replace the composite one that came on the newer truck engines, I had to get a composite one to replace it. So only GM had it and I ordered one.....for $52! After I plugged the sensor hole, and drilled the other hole for a pipe plug, I found out any SBC timing cover will fit. Lesson learned.
Old Dec 17, 2002 | 04:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
some of the old 60's 70's covers have bolt on tab, uses two cover screws on 1:30 postion, had this on a 72 van 350 4 bolt engine, stock painted parts
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
