Metallic scraping nosie
Old Dec 18, 2002 | 05:54 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
This happens (so far as I've noticed) on a high speed curve.
(I'm not on the brakes)
Any ideas?
thx
Old Dec 18, 2002 | 07:39 PM
BOTTLEDZ28's Avatar
Transmission: A4
Check the fluid in the rearend. pull the plug and stick your finger in their. the oil level should be just under the fill hole. also, if you have a limit slip(or posi) rear then the proper additive has to go in when doing a fluid change.
take the rear wheels off and check for rubbing in the inner fender well. Sometimes the tire rubs from the body shifting. if you taking a high speed left turn the right tire would rub and vise versa
Old Dec 18, 2002 | 09:02 PM
Vader's Avatar
If this is in your '87 1LE, it should be very easy. That car should have come with a Borg Warner 9-bolt rear axle, so there is a rubber plug in the rear cover for checking oil level. Very easy.
Old Dec 18, 2002 | 09:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like a combination of "audible wear sensors" and slightly loose front wheel bearings. Getting on the brakes should silence it.
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Feb 25, 2016 09:50 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
