Heads Question
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Heads Question
Are the intake manafold bolt patterns on fuel injection heads (more specifically TBI) diffrent from carberation heads? Like can i bolt the intake from an LG4 onto heads from an LO3?
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Correct, but so do the 87 LG4's,
Now there are 3 basic head to manifold bolt patterns. The pre 86, 87 to 95, and the Vortecs. Now It all depends on the combo your going for. The LG4 came with both the pre 86 intake and the latter in 87 with the upright 2 middle center bolt hole. If the intake is an 87 then the heads from the L03 will bolt right up (reverse that statement and It'll make more sense LOL). Anyway you see were I'm going with this. The L03 was started in 88 IIRC and replaced the carbureted 305 (LG4,82 to 87). So.... the LG4 intake will have to be an 87 to bolt right up. Personally though I would go with an aftermarket intake whether it be a Performer RPM or a Holley. I'm sure the factory manifold left much to be desired.
Car: 1986 Trans Am
Engine: 5.7 Carburated
Transmission: t5
all gravy
shoot they either work or not. course im sure you dont want to go through the hassle but hey i think if anything will work but just doesn't fit exactly just mod it an then you will be all gravy.
i used to think of the same problem
SaSc
i used to think of the same problemSaSc
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
NinjaNife
Aug 23, 2015 11:49 AM
